case 350b power shuttle
NathanY
03-04-2008 20:49:52
I have gotten much advice here regarding olivers but now have an issue with a case 350b that I can"t find the complete info I need. The power shuttle broke a gear on the output shaft and basically destroyed the inners. My question is were would anyone suggest for a replacement unit or since this is a borg warner unit can it be replaced by any borg warner such as the velvet drives used in many inline boats. The tag on the unit seems to have lost it"s markings or is intelligable. Lastly if anyone has a complete power shuttle for a 350b how much would you want including getting it to WA state? Thanks for past and hopefully future help.
mEl
03-05-2008 18:45:00
 Re: case 350b power shuttle in reply to NathanY, 03-04-2008 20:49:52
That shuttle unit is similar to all the units used in The 580 series from the C,s up to the early K's. There should not be any problem finding repair parts. Have seen the reversers you mentioned and the one that I seen was similar in appearance but upon closer exam it had no provision for a converter, it had a front pump driven by just an input shaft, also the shift linkage was vastly different. I presume from your description that a planetary gear failed ruining the clutch drum also? In any event parts are out there and someone reading this forum will be able to help.
NathanY
03-05-2008 21:42:56
 Re: case 350b power shuttle in reply to mEl, 03-05-2008 18:45:00
thanks for the reply after doing more research I agree with you on the differences in other models. someone has offered parts but I think I am in need of an entire unit. after going through mine I realized how much metal got chewed up and spit into the works and run through the torque converter. As far as I can tell, I am probably better off starting with another complete unit and flushing my cooler lines. So if anyone has a compatible shuttle/torque converter please let me know. I also seem to have misplaced the driveline connecting the shuttle to the tranny so if anyone has one let me know what you want for it.
mEl
03-06-2008 04:13:51
 Re: case 350b power shuttle in reply to NathanY, 03-05-2008 21:42:56
the backhoe units have a clutch disconnect that your unit does not have, but it is part of the f/r spool and could probably be changed between units or if space permits just let on there and let disconnected. Also, both pieces are available through Case rebuilt for the hoes. Not cheap though. mEl
mEl
03-05-2008 18:44:57
