830 CK Hydraulic problem
Steve 1953
03-04-2008 19:15:35
830CK Case gas, hydraulics work good when first starting up, after everything warms up there is no hydraulic pressure at all. The pump is almost new. Any ideas?
DKase
03-04-2008 19:59:07
 Re: 830 CK Hydraulic problem in reply to Steve 1953, 03-04-2008 19:15:35
Remove your remote valve, and check the back (front side) for cracks.
Steve 1953
03-05-2008 17:11:27
 Re: 830 CK Hydraulic problem in reply to DKase, 03-04-2008 19:59:07
Thanks to you both, I will try these suggestions.
shoeie
03-04-2008 19:37:05
Some years ago I had a 930CK That had simular problems. I finally tracked the problem to a relief valve that was under the seat deck was sticking. It consisted of a plunger that slides up and down in a cylinder. I would take it apart clean it shine up the plunger and cylinder with emery cloth and it would work like new. This happend three or four times. It's not much of a job to fix. Hope this is your problem and not something serious that might cost a lot. Might give it a try.
