OK found the crack.Can I live with it?
Biomike
03-04-2008 17:20:43
As it turns out #3 liner was cracked(just like you said turbo).The air bubbles came out of the #4 water jacket hole,go figure.The head magnafluxed out fine.
So that crack in question is on number 4 in the block runs from where the liner seats to the center head bolt about 3/8" long.
Would this cause any trouble?
and I still dont get how the water getting into the oil
Thanks y'all
turbo
03-06-2008 17:31:10
 Re: OK found the crack.Can I live with it? in reply to Biomike, 03-04-2008 17:20:43
The counterbore in the block is uneven. It should be 0.250 deep and true. This causes uneven pressure on the sleeve flange and cracks it. It will need to be reclaimed or cut. Case dealers from the 1970's had the portable tooling to repair the block. 1070 or 1270 shims of 0.005 and 0.010 will fit 830's. With the engine shut off, antifreeze comes up the crack in the sleeve and runs down the inside past the rings to get into the oil.
Walt davies
03-05-2008 09:44:21
Anytime that you are getting hot gas from the cylinder into the water jacket it will cause the engine to over heat especially on hard pulls and hot days.
Walt
Biomike
03-05-2008 16:56:32
 Re: OK found the crack.Can I live with it? in reply to Walt davies, 03-05-2008 09:44:21
I dont believe it was leaking around the crack in the block.How could it?The liner was cracked 80% around top.
looking for feed back
thanks
Walt davies
03-05-2008 19:41:03
 Re: OK found the crack.Can I live with it? in reply to Biomike, 03-05-2008 16:56:32
It still has to be replaced as its not seating against the head gasket.
Walt
bradley martin
03-05-2008 02:02:43
YES. I beleive it will cause you big trouble if not repaired.
