Case 530 w/ #31 loader
Dennis/Ohio
03-04-2008 02:51:07
Hello,
My loader drops much too fast. One of the lift cylinders had a elbow at the bottom that had a rubber rod glued inside the fitting (rubber rod looked damaged like it was overheated with a torch etc.). I drilled it out so I could use it like a standard fitting. The other side already had a standard fitting. I have the Case parts & owners manuals. It doesn"t mention this anywhere. Operators manual states: Never drop a loaded bucket too fast and stop it. The control is so sensitive, its hard not to do it. Suggestions?
DKase
03-04-2008 05:46:26
 Re: Case 530 w/ #31 loader in reply to Dennis/Ohio, 03-04-2008 02:51:07
Any good hydraulic shop will have flow restricters that look like a thread in swivel from the outside but have a small hole for the oil to flow through on the inside. If you know what your pump flow is they will be able to tell you what size you need so you will slow the down speed without slowing the up speed. We have a really good hyd. shop in Sioux Falls SD. If you need info email me. DK
Dennis/Ohio
03-04-2008 09:20:39
 Re: Case 530 w/ #31 loader in reply to DKase, 03-04-2008 05:46:26
DK & others
Not to get to lengthy. I"m wondering if anybody has seen a fitting (with rubber inside, rubber round stock laced through the fitting) like this? Also I think it was designed to hold the bucket up if a hose blew? Pump is 20gpm.
Thanks, Dennis....
