580 B trencher/backhoe question
olchief
03-03-2008 19:01:24
drove tractor to park it with normal transmission pressure. upon trying to move 2 days later it refused to move and transmission pressure was just at lower edge of green line on gauge. trans. oil found low, topped up level with no increace in pump pressure.upon starting had excessive noise in shuttle system,probably indicating air entrainment-loosened lines on both shuttle outlets on left side tractor and cannot clear air from this system.pump operates in same manor as previous discription. pump continues to pump oil and air but not enough to operate motion back and forth. when shuttle is shifted only tiny jolt in either direction.tractor filter system has been examined and is good.where can air enter with flooded pump suction? any help with this problem greatly appreciated. olchief 281-857-9576
Amos Fennell
03-09-2008 20:33:47
 Re: 580 B trencher/backhoe question in reply to olchief, 03-03-2008 19:01:24
I had the same problem with my backhoe (580 B). It turned out to be the long pick up tube on the oil pump in the torque tube had a small crack where it was welded into the block that bolted it to the pump. I brazed the tube up not believing that it (the crack) could be the problem and put it back together. It has worked for over 2500hrs since.
olchief
03-13-2008 09:56:51
 Re: 580 B trencher/backhoe question in reply to Amos Fennell, 03-09-2008 20:33:47
mr.fennell, thank you for your reply .i need to talk to you to find out if i have to break the tractor apart. 281 468 9576 thanks again
