finding the crack(does this make any sense?)
Biomike
03-03-2008 14:53:31
Working on my 830 diesel.I have some small air bubbles in the radiator and a small amount of antifreeze in the oil.no oil in water.Block sealer slowed it down but didn't stop it.Attempting to find the leak I pulled the precombustion chambers and it still had some bubbles.Then I ran it without the water manifold and fan belt and found it bubbled around number 4.Pulled the head (again,I had just replaced the rings and bearings)gaskets look good and I'm unable to find any signs of cracks use the solvent technique.There is some heavy pitting on the number four and it seemed like there was some of that block sealer but it could have been rust.Any ideas or other places to look.
all help aprecieated
Walt davies
03-04-2008 08:06:25
 Re: finding the crack(does this make any sense?) in reply to Biomike, 03-03-2008 14:53:31
Have the head resurfaced it could be warped only takes a tiny bit to not seal good.
Walt
Biomike
03-04-2008 04:01:07
The sleeves were used,so its possible.Has new o-rings and went in tight.If it was that small a coolent leak you would think the block sealer would take care of it.If seen it fix much worse.
Roger S
03-03-2008 22:09:04
Mike: I located cracked heads on a 500 by removing injectors and water manifold on top of heads, filled with coolant to top of cyl head, turned each cyl to TDC, put air pressure in injector hole, and watched for bubbles. Found two of the heads bad. Worked good for me.
Biomike
03-03-2008 17:12:52
Could you see that crack with the liner in?I had just replaced those.How could that explain the water in the oil though?
More info: the fire rings(gaskets) where crushed down to .087"-095". on both 3 and 4
bradley martin
03-04-2008 02:12:38
 Re: finding the crack(does this make any sense?) in reply to Biomike, 03-03-2008 17:12:52
If the sleeves are new, I doubt that is your problem, but when they do crack it frequently results in leakage at the bottom of the sleeve(around the O-ring doughnuts) as the sleeve begins to move up and down slightly w/ each stroke. I suspect a cracked head. Get them magnafluxed would be my first step.
DKase
03-03-2008 18:28:34
Have your head magna fluxed, or better yet pressure checked. Cracks are generally around the valves, or between them. DK
turbo
03-03-2008 16:11:18
Odd are #4 sleeve counterbore flange is cracked.
It will be between where the fire ring sets and the fire dam on the sleeve. The crack will go straight down into the water chamber.
