case/david browm885 diesel tractor
WR
03-03-2008 08:29:01
just purchase at estate auction want to change all fluid levels but dont know oil spec. on engine trans power steering also any info on how to use hyd lift selector switch thanks,
Davejd620
03-03-2008 16:18:04
 Re: case/david browm885 diesel tractor in reply to WR, 03-03-2008 08:29:01
After Case took over David Brown we used their hy tran oil in the transmission as it is presure lubed. Same gearcase also supplies the hydraulics and the rear end. When standing behind the tractor if memory serves moving the selector switch to the left was for draft and center was for position control to the right was for remote operation if it has a single outlet.To change the switch hold the 3 pt control back against the spring while moving it.
Hope this helps
