430 power steering question
Don Rudolph
03-02-2008 15:38:06
The power steering takes about 15 seconds after the tractor is started to begin working. Is this normal or am I going to have to rebuild another piece of this machine? Thanks, Don
bradley martin
03-03-2008 16:13:53
 Re: 430 power steering question in reply to Don Rudolph, 03-02-2008 15:38:06
Don; How cold is it where you ,or more importantly, where the tractor is sitting? If it is in an unheated, sub zero enviroment I would expect a time lag before the pump builds pressure. Another easy possibility is air in the system. Turn the steering wheel post to post a few times should eliminate any air, but again, if temperatures are cold, it might take longer. Any leakage evident at the cylinders or hoses?
bradley martin
03-03-2008 02:19:00
Don; You will need to state the year and type of front axle as the 430 used different set-ups depending on the yr and whether it is ag or industrial front axle. Are any leaks evident? It should not take 15 seconds to pressurize the system.
Don Rudolph
03-03-2008 15:58:02
 Re: 430 power steering question in reply to bradley martin, 03-03-2008 02:19:00
It is a 1969 adjustable wide front with the double hydraulic rams under the oil pan area. It seems to work just fine after about 15 seconds of nothing. We have changed both the oil and filter on the pump. Don
