Case 646
DOK
03-01-2008 07:07:04
I am looking at a Case 646 with loader and tiller to purchase. Seller indicated the tractor moves slowly indicating a problem. However, the loader works fine? any suggestions on possible problem and cost to repair? Thanks.
Eldo case
03-01-2008 13:50:27
 Re: Case 646 in reply to DOK, 03-01-2008 07:07:04
It sounds like the hydraulic motor is wore. Will it pull ok in reverse? When they ware it is in the forward side but will backup ok. Check that out. Hope this helps.
Gene Dotson
03-01-2008 13:49:49
My 644 had the same problem. It has a complicated travel linkage. The problem was the lower cross linkage was worn enough to prevant full travel on the travel spool. I took the linkage apart and welded up the worn parts. Made a few other adjustments that give more travel.
Might also need the pressure regulating valve adjusted. It is on the rear of the travel valve... Gene
J Heitkemper
03-01-2008 07:10:39
Could it be that the 630 is a Case -O -Matic and no one there has no idea about how to operate the old girl ?
John Noname
03-01-2008 09:56:43
 Re: Case 646 in reply to J Heitkemper, 03-01-2008 07:10:39
I assume the gentleman is speaking of the loader garden tractor as he talks of a tiller. Would assume its in the travel spool. Don't have any manuals anymore. Someone here may have info or he should post on the Case garden tractor forum also.
J Heitkemper
03-02-2008 14:52:53
 Re: Case 646 in reply to John Noname, 03-01-2008 09:56:43
OOps ,, probably right , I stand corrected , Jim
