930-931 what's the difference
Regan
03-01-2008 06:36:49
Just curious. I seem to remember years ago looking at a 930 as stated on the decal, however the owner said it was a 931. What"s the difference?
bradley martin
03-02-2008 03:35:57
 Re: 930-931 what's the difference in reply to Regan, 03-01-2008 06:36:49
Western Specials had a set-back front axle, wide rear fenders, wide swing drawbar, no 3 pt , and a few other differences, incl. different wheel and tire options. 730/830 westerns had non-adjustable rear and front axles, late model 930/1030 westerns had adjustable axles, early ones did not. There were also "hybreds", where the wide swing drawbar was deleted andthe 3pt installed, leaving only the side fenders and set-back front axle to differentiate from the row crop version.
Regan
03-01-2008 16:51:39
Next time I see an old Case I"ll check it out. The number is found on the serial number plate, right?
Regan
03-01-2008 11:26:04
Thanks for clearing that up. Does the same apply to 1030,830,and 730 etc.?
bradley martin
03-01-2008 12:52:14
 Re: 930-931 what's the difference in reply to Regan, 03-01-2008 11:26:04
Yes it does....in fact in the 730/830 you will find 733,734 and 735 configurations too. I don't remember off the top of my head which each one is but one of those will be orchard, high clearance, etc.
bradley martin
03-01-2008 08:09:23
931 designates it as the rowcrop version, 932 would be the western special version. Likewide, if it was a 941 on the tag, it would be a spark ignition(gas/propane) rowcrop, 942 a gas powered western special . The decals on all of them would say 930.
Texas Sand
03-01-2008 17:13:10
 Re: 930-931 what's the difference in reply to bradley martin, 03-01-2008 08:09:23
I've been reading about the "Western Special". What exactly is different about those tractors?
