Larger Hydraulic capacity for DC?
grapefarmer
02-29-2008 18:55:16
I believe the 1950 DC can hold 2.5 gallons of hydraulic fluid. I am needing to run six separate hydraulic cylinders on my grape harvester. They are adjusted one at a time, but I need more reserve capacity. Any idea how I can plum a second hydraulic holding tank? I guess I could screw a line into the fill fitting and drill and tap another fitting at the bottom. But if anyone has a better idea I am open for suggestions.
Thanks
-Dave
Jim McVay
03-02-2008 04:54:23
 Re: Larger Hydraulic capacity for DC? in reply to grapefarmer, 02-29-2008 18:55:16
We are currently buying fertilizer spreaders that require large amounts of hydralics and with all of the weird hydralic systems onnnew tractors the spreader builder has used a resvoir on the spreader and a pto mounted hydralic pump to run it so it is on its own system. If thr grape harvester had its own system any tractor with PTO with or without hydralics could pull it.
mEl
03-01-2008 09:56:05
The difference in the amount of oil from side to side would be the amount of displacement the rod takes up in the cylinder, not a lot even for several cylinders, the oil removed from the reservoir would have to be replaced as it is pumped into the cylinders but after they are full, very little change in level should be noted as they are operated, the low pressure system is of more concern, make sure the DC pressure rating is sufficient.
bradley martin
03-01-2008 13:00:48
 Re: Larger Hydraulic capacity for DC? in reply to mEl, 03-01-2008 09:56:05
On White corn planters, the lift cylinders are plumbed in such a way that the oil expelled from a 3 and1/2 "cylinder flows to a 3" cylinder to lift the other side of the planter. That gives you a bit of an idea of the difference in volume. I don't know how frequently the cylinders on a grape harvester need to cycle, but the small resevoir might also result in very high temperature oil. Also, any leakage and you run the pump dry very quickly. Considering the low volume/low pressure pump on the DC, Mathias' idea of an auxilliary pump or a different tractor might be worthwhile exploring.
Den N Ms
02-29-2008 19:08:24
Are they one way cylinders,or two way?
grapefarmer
02-29-2008 20:45:08
 Re: Larger Hydraulic capacity for DC? in reply to Den N Ms, 02-29-2008 19:08:24
Two way.
Dutchman
03-01-2008 06:06:24
 Re: Larger Hydraulic capacity for DC? in reply to grapefarmer, 02-29-2008 20:45:08
If they are 2 way ... you will be putting in oil while you are taking out oil.... the level should stay the same... you push oil from the one side of the cyl. while you push oil in the other side.... That's only on 2 way cyl. Hope this helps..... Mark
grapefarmer
03-02-2008 07:57:47
 Re: Larger Hydraulic capacity for DC? in reply to Dutchman, 03-01-2008 06:06:24
Good point!
-Dave
Mathias NY
03-01-2008 06:42:03
A normal 2way cylinder will not return the same amount of oil to the tank that it uses on extension, maybe half. Depending on the size of the cylinders, it is possible to runout of oil. Do you have an early or a late DC? Some of the late DC's have a return line into the oil filter. I suppose it might be possible to plumb an extra tank into that fitting.
The DC's had a low pressure hydraulic system. Have you tested your harvester to see that it can actually be operated by the DC? If it is not sufficient pressure, you may be able to get a PTO shaft extention and run an axilliary pump on that. This will give you all the pressure you need and you can make a tank of whatever size you desire.
grapefarmer
03-02-2008 08:10:22
 Re: Larger Hydraulic capacity for DC? in reply to Mathias NY, 03-01-2008 06:42:03
The grape harvester mainly runs off the pto, with a large mounted pump for the shakers, blowers and conveyors. I was hopping to use the tractors hydraulics for the adjustment cylinders - hight adjustment (one one each wheel), side hitch movement (one large one) and 2 on the side conveyor. Once they are adjusted the are not moved much during harvest.
Yes, I know I should be using a newer tractor, but there is not much money in grapes and I am not borrowing to support this side business. But there are some advantages to the old DC, its heavy, it has the HP needed and its short wheel base is an advantage. Plus is paid for. ;)
Thanks for all the help. I will take some picture of this thing in operation this summer.
-Dave
