detroit engine retrofit
steve21757
02-29-2008 17:45:17
I am in the process of attempting to retrofit a Case 500 with a detroit 3-71 engine.We have everything figured out for the front of the engine, and have some idea about mating the detroit bellhousing to the Case trans.We need some help on how to do thework of mating the clutch and the flywheel together inside of the trans case.If anyone has done this or knows of someone who has, PLEASE email me back with name number or info on how to. THANKS STEVE.P.S there is around 4 to 5 inches of space to be made up between the pressure plate and the input shaft of the trans.need some ideas on how to make up the distance.
Biomike
03-01-2008 17:16:21
 Re: detroit engine retrofit in reply to steve21757, 02-29-2008 17:45:17
Steve,
Have you heard a 3-71 detroit or screaming demon as they are often called.They make all their power at the top end.Just curiuos, why a detriot?
steve21757
03-01-2008 17:29:22
 Re: detroit engine retrofit in reply to Biomike, 03-01-2008 17:16:21
I have an Oliver super 99 GM and also an Oliver 1900 GM.They both scream and make tremendous power,not all at the topend.They are crowd pleasers and I love to hear them scream.I worked for a trucking company when I was a teenager and all of the trucks (75 of them) were Detroits.LOVE EM.
Neitractors
02-29-2008 18:51:36
Check with Don Livingston in Austin,Mn.He has some literature on the subject.I have a nice LA with the conversion.I'm the second owner,but don't know much about the conversion.Detroit did alot of marketing on the conversions in the early 50's.We also have a MM GB with a 3-71.Mike
Den N Ms
02-29-2008 18:10:42
Steve,You might try finding and looking at some of the many different flywheels used behind detroits used in trucks. Some are 4-5 inches thick multidisk clutches.Maybe you could rig a spicer clutch.
