580C Hydraulics
Greg180
02-29-2008 10:57:41
I have a a couple of hydraulic seals leaking on my 1978 Case 580C. One on the front bucket one on the backhoe. Has anyone ever changed the seals? I read through the manual, looks complicated, I and can order the parts and the tools to do it. The tourqe wrench looks like a monster. Is it better to have a professional do it ? Does it require a full rebuild or can you just replace the seals ? I am pretty handy and was a mechanic many years ago, but I don"t want to get into something that is way over my head.
joe francano
03-02-2008 13:01:34
 Re: 580C Hydraulics in reply to Greg180, 02-29-2008 10:57:41
It is a fairly easy task. You just have to get over the scale of what you are working on.
First unpin the bucket where the piston is attached to. Make sure you can get the piston out and the bucket is where it is not in the way. Best bet is to get a good pin type spanner nut removal tool. You will remove the flat head screw on the outside of the cylinder. Then you use the spanner tool to spin the spanner nut out of the end of the cylinder. Then pull the whole piston out. Have a bucket under the end, there will be a gallon or so of fluid that leaks out. There will be a big nut (Called the gland nut)at the opposite end of the piston than the eye end. Remove the nut, then you will be getting there....
Then pull the spanner nut off of the piston. There will be two seals that need to be replaced there. Drive the old ones out, then put the replacements back in. Be careful driving the seals in, you can easily damage them and they you would be leaking again. There is a correct and incorrect way to put them in. There should be illustrations with the replacement sets to show you.
Then the packing will have some seals that are pretty much just wrapped around the packing.
You assemble everything the way it came off.
You may want to look at the piston for wear inside. Some prefer to clean up the inside with a cylinder cleaning tool that looks like a drill bit with a ball made of about twenty little abrasive balls. Go lightly, if you do this too deep, the cylinder will leak internally and you will never have power.
Good luck. Dont fear the job.
Phil (NJ,Az,Sask)
03-02-2008 14:57:35
 Re: 580C Hydraulics in reply to joe francano, 03-02-2008 13:01:34
[Quote]First unpin the bucket where the piston is attached to. Make sure you can get the piston out and the bucket is where it is not in the way.[/quote]
Like Joe says, leave the Cylinder & hoses connected and use the UNIT as your work bench.
After you get the piston Pulled (come-a-long) you
need to put the piston EYE back in its bracket (Pin) to hold the piston while removing the big nut on the end of the piston. You need a breaker bar with Snipe (4' pipe) for that nut.
Good Luck
