VAC engine upgrade
Jim McVay
02-29-2008 09:34:38
I'm working on a buddys VAC. It is currently stock. He pulls it and wants more power. We have to use a stock VAC block and head and manifolds. I did one for myself installing a 300 crank and pistons. I want to use a 300 crank in this one also but want to go to 3 5/8" pistons. I'm looking for pistons that use a .8592 wrist pin, 3 5/8" diameter and a compression height of about 2" (center of wrist pin to the top). Can anyone help?
Eldo case
03-01-2008 13:45:26
 Re: VAC engine upgrade in reply to Jim McVay, 02-29-2008 09:34:38
The sealed power pistons also have a .31 Dome. That wasn't in the piston spec. I found that in the IHC listing. I don't know how that will work with the head combustion chamber but it could be machined off. Just have to balance them all the same. What sleeve are you going to use? It don't look like a VAC will bore that much. I think a Sealed Power sleeve number SO-1993 would work with a little outer machine work. It don't have the o-ring grooves on the bottom but it measures 3.839 and the VAC sleeve measures 3.715 at the bottom. It is a little longer than the VAC sleeve. It looks like it would work with a help.
Eldo case
03-01-2008 13:08:31
One spec. I forgot is the compression hight is 2.024 on the sealed power piston.
Eldo case
03-01-2008 07:20:00
How about a piston for a C-263 IHC for a 560. Bore 3.562
Length 3.780
Dist. between bosses 1.500
Compression rings 2-3/32"
Oil ring 1-1/4
Aluminum piston
Full floating pin
Pin Dia. .8748
The Sealed Power part number I have is a 2468P
I hope this helps we thought about using these.
Jim McVay
03-01-2008 18:13:23
 Re: VAC engine upgrade in reply to Eldo case, 03-01-2008 07:20:00
THANKS
JGarner
02-29-2008 13:15:48
I believe the 53 and 54 SCs used 3 5/8" pistons. mEl you have any idea on this one?
mEl
02-29-2008 17:39:06
 Re: VAC engine upgrade in reply to JGarner, 02-29-2008 13:15:48
I guess the thing to do would be to get with a rebuilder and most are glad to let you snoop through the piston catalogues, thats how I found the 4 5/8 pistons for our DC. I would start with continental as they are very similar as the early VAC blocks were cast by Continental, they even use the same front crank thrust washers and shim setup. some rod brgs were the same. I don"t have any recent catalogues. mEl
