possible newbie 210b questions
t4 mike
02-29-2008 08:59:34
thinking of buying a 210b according to tag. the tag doesn't seem to say if its ag or industrial. it does have forward/reverse shuttle.
whats the major difference between the ag and industrial models?
how does serial numbering work? is it correct about industrial production numbers being under 500? i'm wanting to use this tractor with its loader, am i making a mistake doing so if it turns out tobe a possible collector machine. thanks for any help.
BarryfromIA
02-29-2008 16:40:18
 Re: possible newbie 210b questions in reply to t4 mike, 02-29-2008 08:59:34
A 210b may be rare but does not make them much more valuable than other CASE tractors of a similar size . They are handy because of the size and are easy to get off an on compared to a big tractor with a cab. CASE built many 310 and 310b's which are very similar. I have a 210b-h.
iluvcase
02-29-2008 10:08:55
Mike: The Case model 210B Utility tractor was considered the industrial version of the 200 tractor....the 211B was the General purpose or ag. model. They made 178 210B'S in 1958 ....the serial #'S for that year are....6095001-6115200. In the year 1959 they made 203 210B's....serial #'s 6120001-6140000. My uncles first Case loader-backhoe tractor was a 210B. That was a long time ago. It's a tough little tractor....i hope that you enjoy it...they are rare.
Scott 210B - Indiana
02-29-2008 09:51:44
I am far from an expert but I bought one of these last October. From what I have seen the main difference between the ag. and ind. models is a heavier front axle on the ind. with lower ground clearance. Rear axle/wheels on my tractor are also unadjustable. I have no aux. hydraulic lines. The difference between ag. and ind. might also be blurred by options. I do have the pto and Eagle hitch while some 210b's do not. Mine is a 1959 with power steering, Dual Range Shuttle, easy ride seat, pto, Eagle hitch, model 21 loader. My dad and I (mostly dad) nearly have it restored. I could not find 210b dual range shuttle decals for the sheet metal so I had 4 sets custom made. Even though rare and restored, I plan on using this tractor.
