case 1594 diesel in oil
rickz
02-28-2008 07:51:29
My 1594 case has been loading the crankcase with diesel.I have changed out the lift pump(twice),blocked off the cold start line to the intakes and monitored the power steering pump for leakage.The injection pump is taking no diesel fuel into its sump and I tried running the tractor with the pump level plug and overflow disconnected to see if it was overfuelling while running.Eveything checks out and I am still taking diesel in at a a rate of a quart every couple of hours.Will a faulty injector cause this
or could rings or valves be suspect.Any ideas would be appreciated.
Rickz
Ronnie Sparks
02-29-2008 16:22:46
 Re: case 1594 diesel in oil in reply to rickz, 02-28-2008 07:51:29
faulty injectors can cause this in other types of diesel engines.
