580D CASE BRAKES LOCKING
RAY BERG
02-25-2008 20:35:23
I HAVE A 1982 CASE LOADER BACKHOE WHEN I HIT THE THE BRAKE PEDAL REAR LEFT WHEEL LOCKS UP,I PUT IT IN REVERSE THEN FOWARD AND IT RELEASES,IT IS TWO WHEEL DRIVE, DOES ENEY BODY KNOW WHAT CAN CAUSE THIS THANKS.
swood
02-27-2008 03:35:24
 Re: 580D CASE BRAKES LOCKING in reply to RAY BERG, 02-25-2008 20:35:23
There is a band around one disc and that disc is not driven by the tranny. The other disc is driven by the tranny when you press the brake pedal it stops the undriven disc. These two disc's are held together by two stiff springs and they have four steel balls in the middle that set in elongated cups, so when one disc is stopped it causes the discs to expand against the tranny housing and the brake housing. If the brake pads are worn enough then it will allow the steel balls to get in a bind in the elogated cups causing the brake to stick. Usually a new set of pads riveted on will solve the problem unless the housing is worn to much. Hope this helps
Walt Davies
02-26-2008 17:17:17
I'm not sure but doesn't the 580 have disk brakes on the side of the tranny frame. If so its easy to remove and clean them you most likely have brake fluid on the disk.
Walt
Roger (Mi)
02-26-2008 02:34:52
 Broken parts or rust... in reply to RAY BERG, 02-25-2008 20:35:23
There are springs that retract the brake bands and disks. They are likely weak or broken. Rust will cause the same problem. You'll need to disassemble, inspect, replace, and clean.
Mikeleone
03-11-2008 17:15:19
 Re: Broken parts or rust... in reply to Roger (Mi), 02-26-2008 02:34:52
I second this one, those srpings that retract the shoes or a buildup of grease and gunk holding the shoes too close the disk assembly
