995 CASE DAVID BROWN
995 4 WHEEL DRI
02-25-2008 08:45:43
I HAVE A 995 CASE OR DAVID BROWN, IT HAS THE 4 WHEEL DRIVE FRONT END IT HAS A BLOWN MOTOR, THE GUY I BOUGHT IT OFF SAYS IT NEEDS A 995 OR 1210 MOTOR ONLY, JUST WONDERING IF ANYONE HAS ANY INFO ON THESE TRACTORS.
ArleninOr
02-25-2008 14:32:34
 Re: 995 CASE DAVID BROWN in reply to 995 4 WHEEL DRIVE, 02-25-2008 08:45:43
Yes they were factory 4 wheel drive.Those engines were not a sleeved engine to my knowledge. 219 cid can come out of a number of case/david brown tractors and some later {1981 up} case models. Check with some of the salvage yards close to you. Hope this helps.
995 4 WHEEL DRIVE
02-25-2008 10:50:04
when the rod bent it broke an ear off on the cylinder sleave, from what i have been told it was over bored and then sleaved with 1210 sleaves, i have only seen a hand full on these tractors around that are 4 wheel drive, does anyone know if they were factory 4 wheel drives or if they were mods?
ArleninOr
02-25-2008 09:28:46
What do you mean by a blown engine? There are a number of blocks that will fit that tractor. Give Elmer a holler on this board.
