QUITE A JOLT
canadian northe
02-24-2008 06:55:26
I PUT THE MAG FROM MY CASE IN THE WORK BENCH THEN SPUN HER AROUND WITH THE ELECTRIC DRILL AND BOY DID I GET JOLTED. IS THIS NORMAL O YEAH I STUCK A WIRE PRONG INTO ONE OF THE PLUG HOLES AT THE SAME TIME.DO I HAVE TO DO THE SAME WITH THE OTHER THREE PLUG HOLES IN THE END CAP TO BE SURE IT WORKS ON ALL FOUR?
lighting the world
02-26-2008 18:18:03
 Re: QUITE A JOLT in reply to canadian northerner, 02-24-2008 06:55:26
I'll agree totally on having zapped myself a few times..... ok at least once a week. I have done it on gm coils, water heaters, and had a cousin talk me into peeing on a dc electric fence (never forget that 1).
but ya gotta admit that its funny when somebody else does it for once!!!!!
Walt Davies
02-25-2008 17:18:34
Sorry about that but to us old timers who work with this stuff all the time its nice to see that we aren't the only ones who get bit by one.
When you turn it over by hand it should turn very hard and then snap as it goes past the slow speed holds on the mag. if it does not snap then you need to get it repaired.
Goto this site for a lesson how to fix and test mags.
Walt
JThomas
02-25-2008 10:41:00
Remind me of the time we were working on a mytag motor . My youg son grabed a wire in each hand while my older son kicked it over to see if they had a bite . well they did and ten minutes later my younger son started to whistle never could before. I wanted to hook him up again to see if we could get him to play the piano.
j Heitkemper
02-24-2008 19:52:37
kinda reminds Me of the FFA days .. Practice Chapter Meeting Contest,, when A guy made a motion to cut the Cows legs off on one side so the Cow could Accomadate Our hilly Farm ..Never mind the rib poking , I am Sure everyone responding has Done something That We All Could tease about , however Old is correct that the Mag spins at a slower RPM than a cordless Drill . Simply hand spinning with a spark plug wire is best Way I check Them . Blessings . Jim
canadian northerner
02-25-2008 06:42:44
 Re: QUITE A JOLT in reply to j Heitkemper, 02-24-2008 19:52:37
THANKS BUD ANY HELP IS APPRECIATED WHEN YOUR GREEN LIKE ME.
canadian northerner
02-25-2008 06:42:25
Walt Davies
02-24-2008 09:47:26
You Canucks are something else, next time stand in a wet spot for better conduction of the spark voltage. If your eyes light up then its Ok.
Walt
canadian northerner
02-25-2008 06:40:30
 Re: QUITE A JOLT in reply to Walt Davies, 02-24-2008 09:47:26
BOY ARE YALL SUMPIN ELSE.
old
02-24-2008 09:26:14
Wound you believe you didn't really find out if it works or not. Why you ask well that drill would spin it fast enough that even if it was weak it would zap you. A mag should zap you when you spin it over by hand. As far as testing it you don't need to feel the spark take a plug and hook it up and then lay the plug on the side of the mag and spin it by hand. If you get a good white.blue spark then the mag works as it should. DON'T use the drill to test it because you don't spin and engine that fast when you start one so you will not have as strong of a spark
canadian northerner
02-25-2008 06:47:11
 Re: QUITE A JOLT in reply to old, 02-24-2008 09:26:14
THANKS OLD WHEN I BOUGHT THE MAG OFF EBAY THE GUY SAID IT FIRED A STRONG BLUE SPARK.I PLAYED AROUND WITH IT ON THE BENCH BUT COULDNT GET A STRONG BLUE SPARK SO I FIGURED I WAS NOT SPINNING IT FAST ENOUGH. SURE WAS A LESSON FOR A GREENHORN LIKE ME.
lighting the world
02-24-2008 07:48:18
sure definitely do that..... . but you should do it for about a minute in each hole to be sure the condensor doesnt croak out. and be sure to hold the wire prong tightly!!!!!
canadian northerner
02-25-2008 06:38:24
 Re: QUITE A JOLT in reply to lighting the world, 02-24-2008 07:48:18
THANKS FOR YOUR TYPICAL ANSWER PAL.SURE FEEL GOOD TALKIN TO YALL.
Doc Larry
02-25-2008 19:07:41
 Re: QUITE A JOLT in reply to canadian northerner, 02-25-2008 06:38:24
Glad you"re a good natured sport. But where did YALL come from? Don"t tell me all the Texsuns went north??
