Case Eagle Medallion question
Don Rudolph
02-23-2008 12:09:53
Can anybody tell me what type of fasteners are used to hold on the Case eagle between the headlights? Thanks! Don
bradley martin
02-24-2008 09:47:55
 Re: Case Eagle Medallion question in reply to Don Rudolph, 02-23-2008 12:09:53
John is absolutely right with the name"tinnerman nuts". They are found in the "speed nut" section of most fastener catalogues (along w/ a whole bunch of other types of speed nuts). Joe's diagram shows what they look like. If you have an old one, take it to a fastener supplier and thy will fix you up.
Den N Ms
02-23-2008 19:01:57
Don,you might try at a auto body shop show them the eagle and they might have some molding clip nuts that would work for you.
genos
02-23-2008 18:32:56
I Got Mine At Ace Hardware
John Saeli
02-23-2008 16:47:35
Hey Don: Because they are not designed for threads, I believe they are called "Tinnerman Clips".
Joe (Wa)
02-23-2008 16:44:20
third party image
Kinda crappy pix. Same clip (speed nut)as used on the CASE nameplate. Joe
Larry59
02-23-2008 13:49:19
Hummm interesting... that is what I was wondering about. So now I know what to look for. Thanks
bradley martin
02-23-2008 12:59:36
Technical name is "speed nuts"...still available from fastener outlets...they are a rectangle of thin, spring steel w/ a hole and a slot...not avery good description but...
