cleaning fuel tank
Kevin in Iowa
02-23-2008 11:00:21
I have crap in my gas tank. Does anyone have any easy tips on how to clean it out. Thanks
TexasWren
02-25-2008 07:00:08
 Re: cleaning fuel tank in reply to Kevin in Iowa, 02-23-2008 11:00:21
DON'T USE AIR. A pressure washer is safe, but blowing air causes static (which is why shop-vac hoses will shock the snot out of you). A static electricity spark in the middle of a bunch of blowing fuel mist is just about what happens in a cylinder, with about the same results.
Bruce Hopf
02-25-2008 02:53:14
Kevin
I would remove the tank, and do a thoural yob of cleaning it out. I'd use diesel fuel to flush it out, swish it around. I'd do it 2-3 times this way. A couple of times after with varsol, and you should be set. I had to do this on a few tractors. I tried with the tank on with no succes. After doing it once, and not working getting it properly clean, wound up doing it the other way any way. Save your self thime and remove the tank. Hope this helps
Den N Ms
02-23-2008 19:12:55
Kenen ,Use your shop vac after you get all the gass drained out and the tank dried out.Hook the hose up to it so it blows out air to dry it out and clear the fumes.Then change it back to vac when it totally dry.If you need a smaller hose to get to the bottom, tape a piece of 3/4"heater hose to the big hose.
J Heitkemper
02-24-2008 19:59:35
 Re: cleaning fuel tank in reply to Den N Ms, 02-23-2008 19:12:55
Please Defend ! Have You REALLY DONE THIS? . Without Adverse Consequences as others Describe ,,Sounds like Bad advice ,.. However it also Seems Plausable to work ..,No Response to All Should Mean a definite NO-No
Dick from West Point
02-23-2008 19:04:32
Kevin, Please DO NOT use a shop vac they are electric and GAS FUMES will BLOW UP!!!!! !!!!!
farmdad
02-23-2008 18:55:09
I wouldn't use a shop vac. The motors on them usually spark when they are running and you would be sucking in gas vapors. This could cause a big boom.....
amo
02-23-2008 18:09:45
TRY A SHOP VACCUM
old
02-23-2008 11:37:55
A lot depends on what it is. If its rust what I do is drop in a few large nuts and shack the tank real well. Then dump them out. Be sure to count how many you put in so you get them all back out. I then fill with filtered waste oil and shack it real good and then drain the tank out again. The oil picks up and holds the rust so you can get most of it out
Kevin in Iowa
02-23-2008 15:10:44
 Re: cleaning fuel tank in reply to old, 02-23-2008 11:37:55
I was thinking more while its on the tractor.. is that possible??? It actually looks like seeds or something in there.. I took my carb & sediment bowl off and cleaned them really well but after the first test run sure enough there was, what looked like, seeds or something in the bottom of the sediment bowl???
Roger H
02-23-2008 17:55:38
 Re: cleaning fuel tank in reply to Kevin in Iowa, 02-23-2008 15:10:44
Several years ago I got an M Farmall that did nothing but pick ear corn, by the looks of the inside of the tank it had to sit with the rest of the year with a "not full" tank, I put ethanol gas in it(and still do) & in a short time the sediment bowl was full. I finally had to remove the tank & take it to the neighbors lawn mower shop & used his steam cleaner to get most of the crud loosened up & out of there. Since then I havent had any trouble. I must have got it all out because I havent had to clean the bowl since.
Doc Larry
02-23-2008 17:48:44
Well if it"s seeds and dead bugs you might put an air hose in and see how much you can get to blow out? Worth a try, I suppose.
