Thank you to Elmer
RickB
02-23-2008 07:56:14
Just got in from clearing the driveway with my Case (DB)885. Thought I'd tell you I appreciate the advise you gave me a few years back about this tractor before I bought it. I put pistons, rings and rod bearings in it, installed the power beyond block you sold me, mounted a 6' blower on the back and a 7' plow on front. Great little rig. Brakes and seals are on this spring's agenda.
Elmer
02-24-2008 07:41:49
 Re: Thank you to Elmer in reply to RickB, 02-23-2008 07:56:14
Glad to help Rick. When you do the brakes make "SURE" you tie down the diff lock pedal before you pull the right final drive. Or else the diff lock sleeve will fall to the bottom of the housing, then you will do some cursing! I have done that enough over the years to be able to get it back in place in a matter of minutes, but have seen others fight for two days! The engine in that 885 is one of the best built in its class. Tough little tractor too.
db990
03-20-2008 13:24:14
 Re: Thank you to Elmer in reply to Elmer, 02-24-2008 07:41:49
I have a case david brown 990 that I use in dead weight pulling. Before any more damage is done we need to chase down a problem. When under torque during mid pull it popped out of gear. It did it the first time while the front end was up in the air causing it to come crashing down and then I held the shift lever in while pulling during the next round. The second time it did it while I was holding the lever. The lever never moved but the trans popped out of gear. All it required was to pull it out and put it back in again. I won the pull but we are concerned to get it fixed. I'm wondering if you had any suggestions on what it might be. Pops out of gear but the shift handle doesn't move. I had pulled alot more weight at other pulls with no problems. I love this tractor and want to keep it going. We are going to open up the tranny and examine the slides ect. I would love any input you might have thanks. E-mail if you prefer. Thanks, chris.
Jamey
02-24-2008 06:52:40
I have a DB 885. What is a power beyond block?
Elmer
02-24-2008 07:45:17
 Re: Thank you to Elmer in reply to Jamey, 02-24-2008 06:52:40
The power beyond plate allows the three point hitch and loader to be used at the same time. DB originally had a three way valve that only allowed loader or three point operation.
Jamey
02-24-2008 08:46:53
 Re: Thank you to Elmer in reply to Elmer, 02-24-2008 07:45:17
Thanks for the info. I don't have a loader so I don't guess I'll be needing a power beyond box.
