500B
comfortking
02-21-2008 05:54:47
We have a 500B tractor that has a 164 wet sleeve engine. Does anyone know where one might find sleeves and pistons for this engine? There is a listing in the Case parts book for wet sleeve kit no longer avail. The bore is 3 9/16ths which makes it a 164 as a G-159 has a 31/2in bore. Thanks
jr @beaver machine
02-21-2008 16:13:03
 Re: 500B in reply to comfortking, 02-21-2008 05:54:47
Replacement engines were in fact WET SLEEVES in the 164 case. No parts have been available for a number of years. Not many produced = no parts. Such is this CASE. I have one and would be interested in the sleeves if you find someone to make them. JR
D-C-741
02-21-2008 15:25:58
A 164 IS A DRY SLEEVE Engine ,we had 2 600's with the same Engine ,we sold the one, 15 years ago,the other one got scraped ,it had the M&W kit in it,the Crankshaft broke at the Center Main.the pistons are here,the Sleeves are still in the block.I am not sure if they are use able after it broke.607-564-7536 if you might have any interest.
comfortking
02-21-2008 16:30:36
 Re: 500B in reply to D-C-741, 02-21-2008 15:25:58
I think the early 530 G159 sleeves and pistons may fit. The 164 sleeves measure 4.109 across the top flange and 3.88 at the o-ring. This is the same as the 159 sleeve. The bore is 3 9/16 vs 3 1/2 on the 159. The cranks are the same and the rods are the same as far as I can tell. The last 530's measure 4.57 across the top flange, this is information I was given by my supplier. I'll keep you posted.
D-C-741
02-21-2008 20:50:51
 Re: 500B in reply to comfortking, 02-21-2008 16:30:36
Well my 2 of Uncles and Grand Father were a CASE dealer till 1970 and still repairing them today . So I do know what I am talking about.we have around 70 Case Tractors + several other brands on our Dairy Farm,and do all our own repair work.
george md
02-21-2008 09:08:44
CK, When I get a job in the shop that I can't buy liners for ,I bore and sleeve the old liner as long as the pistons are good. If I have the block it's not too difficult , if I don't have the block I have to make a fixture to hold the sleeve without distorting it . Mostly I do that to the old continental and waukesha engines . Email if you want to chat about it .
george
corey c
02-21-2008 09:06:15
These guys have what yo need, and are good people to work with.
Tom"s Agri-Diesel, INC. 1-800-377-1297
910 Road M47 Harlan, Iowa 51537
[email protected]
Greg Breisch
02-21-2008 17:51:51
 Re: 500B in reply to corey c, 02-21-2008 09:06:15
The engine pieces parts are sold seperatly through case and all avalible. I just bought a whole set for my 500B. If you need part numbers I can provide them for you
