lever
Gwaite
02-20-2008 15:28:11
I have a 1958 Case 411B , Case O Matic tractor . There are two levers on the ( dash ? ) the one on the left is the throttle ,What is the one on the right and what is its function ? I just purchased the tractor .
Genos
02-23-2008 18:42:52
 Re: lever in reply to Gwaite, 02-20-2008 15:28:11
Got My Seal At Local Bearing House, but Case Dealer Could Get From Another Dealer & Could Get Them Shipped To them, got The Gasket From Case. Your Dealer May Have One. Get Number Off Your Old Seal, Starter Rebuilder Throwed Mine Away
Gwaite
02-24-2008 04:40:03
 Re: lever in reply to Genos, 02-23-2008 18:42:52
I removed the starter and it looks like a fairly recent rebuilt one ( clean and has 411 painted on the end with yellow paint ) instead of a gasket between the starter and bell housing they used a blue silicone sealer . ( works OK I guess .) I looked at the Bendix spring and drive gear but didn't see anything that looks like a seal...Does the starter need to be torn down to see /replace the seal ? If no old seal is present how would I find the number of a seal I need ? Truman
Eldo case
02-21-2008 08:23:13
It will have oil in the flywheel area. I would guess it don"t have the correct starter or the seal is bad in the starter. It is a case-o-matic tractor. The one lever is the throttle the other is the direct drive. They are other posts on this site about how they work also. A manual would be a good thing to get for it also.
Gwaite
02-21-2008 09:39:29
 Re: lever in reply to Eldo case, 02-21-2008 08:23:13
I bought a manuel for the 411B ,but it doesn't cover that tractor very well .seems to be more about 311 and such . Yes its a Case O Matic . I'll pull the starter when I locate a [ seal /gasket ] for it . Any idea who would sell such a thing ?
Gwaite
02-21-2008 04:43:05
Thanks Jim ...another question if you don't mind.With the engine running fluid (hydraulic oil ) comes out of the starter motor ..I checked the hydraulic level via dipstick and it was about 1 gallon over full ..I drained it by loosning a hose and catching it in a container. How do I get the remaining fluid out of the ring-gear housing ? Was any damage likely to have occured ? ( maybe I should just drain it all and put in fresh fluid ,altho its clean and clear . )
Gwaite
02-27-2008 05:05:00
 Re: Starter W/ seal in reply to Gwaite, 02-21-2008 04:43:05
Which starter is the correct one ( part # if known ) for the Case 411B , Case -O- Matic .Is the starter ( with the oil seal ) avaliable ? I have seen pictures of 2 different looking ones and am confused .
Jim From Calif
02-21-2008 18:54:15
 Re: lever in reply to Gwaite, 02-21-2008 04:43:05
My Case-o-matic 530 manual says to check the Convertor oil while the engine is idling. I assume the 400 is the same. You may find you are low on oil now that you have drained 1 gal out. (re-check it @ engine idle)
Jim From Calif
02-20-2008 15:47:33
The right side lever locks/unlocks the torque-convertor. (Lever-down is "Direct Drive" & Lever-Up is Case-o-matic drive.)
