1948 Case SC oil pump and Carbuerator
john mayes
02-20-2008 08:48:09
Looking for an oil pump for 1948 Case SC. The casting # on mine is 5612A. Have been contacted about different year possibilities but don't know if they would be interchangeable. Also the 48 SC I bought has a Ford 8N carb. on it and does not work right. Does anyone know what the original would be and know where I might find one.
Thanks,
John Mayes 325 554-7883 or e-mail response.
Gene Dotson
02-20-2008 09:18:15
 Re: 1948 Case SC oil pump and Carbuerator in reply to john mayes, 02-20-2008 08:48:09
John;
The carburetor should be a Zenith 161jx7, PN O-9667.
John Saeli in Geneva New York may be able to help you with the proper carb.
Don Livingston in Austin, Minn. may also be able to help. e-mail is [email protected]... Gene
john mayes
02-20-2008 13:18:05
 Re: 1948 Case SC oil pump and Carbuerator in reply to Gene Dotson, 02-20-2008 09:18:15
Gene, Do you know if that particular carb. was used on SC's other than my 48?
John Mayes
john mayes
02-20-2008 09:40:24
Gene, Thanks for the reply. I'll e-mail Don and give it a try. Do you have John Saeli's e-mail or phone #?
John Mayes
Tom Railsback
02-20-2008 11:29:46
 Re: 1948 Case SC oil pump and Carbuerator in reply to john mayes, 02-20-2008 09:40:24
I saw a little farther down that Don L. is on his way to Florida for the JICCA winter convention.
john mayes
02-20-2008 13:15:14
 Re: 1948 Case SC oil pump and Carbuerator in reply to Tom Railsback, 02-20-2008 11:29:46
Tom, Thanks for the info.
John Mayes
Gene Dotson
02-20-2008 11:22:33
John's phone number is 866-711-6290 or 315-433-9826. e-mail is [email protected] ... Gene
JGarner
02-20-2008 13:22:54
 Re: 1948 Case SC oil pump and Carbuerator in reply to Gene Dotson, 02-20-2008 11:22:33
Gene, thought I read some where that you have a big Case scrap yard in New York. My e-mail is on so if this is true drop me a quick mail and let me know what all you have. I am restoring a 630 Case and am needing a few sheet metal parts in addition to the odd internal part I find that is worn beyond use or damaged.
JGarner
Gene Dotson
02-20-2008 13:27:11
 Re: 1948 Case SC oil pump and Carbuerator in reply to JGarner, 02-20-2008 13:22:54
JGarner;
Sorry, I don't have a scrap yard. That would be John Saeli. His information is in my previous post... Gene
JGarner
02-20-2008 15:00:23
 Re: 1948 Case SC oil pump and Carbuerator in reply to Gene Dotson, 02-20-2008 13:27:11
Know John and Chris, good people, I knew John had some items and I buy from him a lot but mostly new repro parts. Just had to check out somethimng I thought I read somewhere in YT.
JGarner
john mayes
02-20-2008 11:53:55
Gene, Thanks for the info.
John
