buzzing starter
jerry s
02-19-2008 07:10:39
i have a case some one has sent me and the one problem i have found is a buzzing on the starter when you try to start it it is a v.a.c almost like mine.it has on just a buzz and some time it turn the moter a little and buzzed i am kinda leaning to the starter itself.some one said there is a solinoid some where i could use a little help jerry s
C. Amick
02-19-2008 09:09:42
 Re: buzzing starter in reply to jerry s, 02-19-2008 07:10:39
The starter push button could also be corroded and not making good contact. Check the battery ground cable (positive to ground) to make sure it is making good contact with the tractor. I don't think you have a solenoid. I would pull the starter off and hook it up to a 6 volt source to see if will spin.
old
02-19-2008 07:32:42
That could be a bad starter, but it could also be a weak battery, bad battery cables, and or poor cable connections. Any one of those or a combo of those can/will cause that to happen
