I could use some help - will anyone reply?
Jackie in SC
02-19-2008 06:08:44
Perhaps my question is too ignorant, but I really could use some help from anyone who has done this - I am sure that many of you have, and can advise. I would appreciate it!
This is my message from yesterday:
Manifold gasket replacement project was fouled by previous owner"s breakage of two manifold studs. Trying to remove head so that machine shop can work on it without taking whole tractor in...removed sheet metal, radiator,valve cover,thermostat and head bolts. Can the head be removed now by tapping with rubber mallet to loosen seal? Or do I need to remove the rocker arms/push rods first? Please help as I am working on dad"s old tractor.
Doc Larry
02-19-2008 16:42:15
 Re: I could use some help - will anyone reply? in reply to Jackie in SC, 02-19-2008 06:08:44
Sorry, please, don"t use a chisel between the block and head as suggested below.
derik Ohio 08
02-19-2008 15:24:02
on some 188 diesel there is a cap screw behind water pump that must be removed to remove head
J Heitkemper
02-19-2008 22:25:16
 Re: I could use some help - will anyone reply? in reply to derik Ohio 08, 02-19-2008 15:24:02
Thanx for pointing out that bolt .. I remember that one .
Jackie in SC
02-19-2008 08:21:51
Thanks so much, everyone! If I run into any problems, I'll post again. Appreciate your help!
TexasWren
02-19-2008 06:29:25
It depends on the tractor. As HillbillyOH said, you might have to remove the rocker arms (on my Case 830 you have to, because four of the head bolts are underneath them). Also, it's convenient to get the pushrods out of the way just so you don't damage them. It's not unusual for it to be a wee bit stuck, even without sealant, but it should come off relatively easily. Just don't do any prying at the gasket area.
aw hadden
02-19-2008 06:21:56
Yes remove rocker arms and push rods , may need to use a small chisel between the head and block don't gouge just tap chisel lightly till the head and block start to seperate. then use a prybar to finish the job.
hillbillyOH
02-19-2008 06:14:34
I believe you have to remove the rocker arms and tappets first. It is probably a good idea to mark the tappets so that they go back in the same holes as you re-assemble.
Unless the previous owner used permatex or something on the headgasket, the head should then lift right off the block.
