431 withoptional hand operated dry type transmission clutch
arch in ky
02-18-2008 05:54:10
Can someone explain this type of set up???Did it work good???Is it eary to work on???Did it last good??Can you get parts for it??? Thanks Archie
david ackerblade
03-19-2008 17:34:47
 Re: 431 withoptional hand operated dry type transmission ... in reply to arch in ky, 02-18-2008 05:54:10
I have a 1965 530 dsl dual range with a hand clutch.What i what to know is when you stop the tractor with the hand clutch why can't I shift the transmision from forward to reverse?Is mine out of adjustment or when blowing snow do I have wait for the blower to clear and use the foot clutch to change gears.
R F W
02-18-2008 08:47:02
 Re: 431 withoptional hand operated dry type transmission clu in reply to arch in ky, 02-18-2008 05:54:10
I have a Case 430 Diesel and the Hand Clutch works just like Phil described and has not caused me any problems
mEl
02-18-2008 07:35:14
The hand operated clutch is internal to the torque tube and is not dry, it runs in the hydraulic reservoir. Your title left some question. The reservoir should be filled to level, Although TCH would have been the original oil used, Hytran Ultra is the replacement I would use.
bradley martin
02-18-2008 06:55:52
Phil did a good job of explaining how it works. It was a reliable, trouble free operation and parts are readily available.
philcaseinWPA
02-18-2008 06:12:00
If you have what i think you have the hand clutch would disengage the transmission but allow the pto to continue to run. The foot clutch would disengage the transmission and the pto. The hand clutch was not to be used instead of the foot clutch for normal use, only to keep the pto running when you had to stop the forward motion of the tractor. Sort of like the two stage clutches on other tractor makes, gives you a sort of live independent pto. That is how it is on my 630.
Phil
