2670 Steering
kirk in ks,
02-17-2008 05:28:51
how do I fix the telescope feature on this 2670 so it will hold when I turn the knob down?
It wont hold and its all the way down on the steering column,
I see theres little nylon pieces in the lower part but how to fix it ,, i dont know?
Jim B
02-17-2008 18:32:24
 Re: 2670 Steering in reply to kirk in ks,, 02-17-2008 05:28:51
Kirk,
Ya gotta install new "nylon pieces". Requires total disassembly of the steering column. If you can even find new parts.
We did it years ago on our 2470 and it failed again within a couple of years. Not worth the effort. It's a terrible design. Certainly improper use of plastic (nylon). I think they should have used brass but then something else may fail. Just forget it.
By the way.... still asking the question: if you've ever put that 2670 in the field and made it work for it living?
WBWI
02-19-2008 15:26:14
 Re: 2670 Steering in reply to Jim B, 02-17-2008 18:32:24
Same thing I ran in to ended up putting a hose clamp on the telescoping shaft to keep it in place
