David Brown 995
Weldin man
02-15-2008 18:36:01
Pulled the timing cover on a 995 today.Every gear was chewed up. all the teeth on the crank gear was missing, idler gear. inj. pump gear and power steering pump drive gear were all damaged. one tooth must have broken off and went through the other gears. All new gears from case IH are over $1200.00. anyone know where to buy any used DB parts? Thanks.
cj3b_jeep
02-18-2008 05:13:14
 Re: David Brown 995 in reply to Weldin man, 02-15-2008 18:36:01
Might be cheaper to find a replacement engine. I've dealt with Robert's down in S.W. Ohio and they were good to deal with, nice and helpful.
Donald Lovering
02-17-2008 12:36:59
I would also try Wengers of Meyerstown PA. Large part selection ,of used DB parts.
Steven Meckstroth
02-16-2008 15:06:24
You could check with Roberts Farm Equipment is southwestern Ohio. They have dissambled a number of David Brown tractors.
mEl
02-16-2008 03:18:29
Better check your valves and pushrods, if the pistons hit the valves you may have lots of upper end damage.
jcmarleau
02-15-2008 20:22:58
I think I do have a good set of good used gear for 995 timing cover for sale will have to check. my e mail is [email protected]
joe e-tx
02-15-2008 18:42:38
sorry to hear this. fellow 995 owner. same engine as my 1210 except inj pump and front hyd pump.
