case 1370
antonio
02-13-2008 21:48:57
Hi guys
I bought last week a case 1370. I want to ask you if i must have special consideratios with this tractor. I mean, i have read that i dont must to use the PTO with the powershift in reverse, Is this true?
I have read too that when the tractor is doing stationary work with the PTO the powershift must be in range 3. Is this correct?
Everything that you can tell me aboun this tractor, pros, cons, will be thankful.
Greetings
Antonio
Dairy Farmer in WI
02-14-2008 07:14:09
 Re: case 1370 in reply to antonio, 02-13-2008 21:48:57
the way i undersood that is that you can do PTO work in reverse as long as you are moving. if you are say...running the blower or grinding feed, then you just have to have it out of reverse. shouldn't have to have it in 3rd ps range to do sationary PTO work. at least i never did with my 970 Power shift and there are no problems with that.
DF in WI
