David Brown 990 implematic steering box
mlprus8890
02-12-2008 11:59:16
Does anyone know where I can get a steering box "casting" for a david brown 990 implematic? Mine is broken. I have a problen, it steers to the right, but not to the left, the casting broke when I tried to turn left. Any ideas of what might be wrong with it? Thanks in advance.
ArleninOr
02-13-2008 11:56:06
 Re: David Brown 990 implematic steering box in reply to mlprus8890, 02-12-2008 11:59:16
Swapped out one of mine for power steering so I should still have the casting will look this week and get back to you
ArleninOr
02-12-2008 14:00:53
Would this be a manual steering and is it on a brown and white tractor?
mlprus8890
02-13-2008 05:31:19
 Re: David Brown 990 implematic steering box in reply to ArleninOr, 02-12-2008 14:00:53
It is manual steering, the tractor color is red and yellow(headlights on side of hood like fords, not built in to the grill). I figured out the problem, ice. It's winter and the snow melted off the tractor and got into the gears through the broken casing, froze up and turned to ice. I heated it up with a torch and the ice melted and water started pouring out of the seperation. I still would like a casting though, if I can't find one I'll probably try to get this one heli-arc'd(cast aluminum alloy). Thanks.
