580 CK backhoe motor?
Wendell Johnsto
02-10-2008 19:32:12
I was wondering if there is any other kind of motor that can be grafted in place of the original motor in the 580 CK backhoe either gas or diesel.
mEl
02-12-2008 04:14:00
 Re: 580 CK backhoe motor? in reply to Wendell Johnston, 02-10-2008 19:32:12
The kit to put the 3.9 engine in was for the c-d series with the unitized chassis. the solid tractor types are locked into the engines mentioned by Tom. A combine 201 would be my choice and can be found reasonably. mEl
Wendell Johnston
02-13-2008 15:12:15
 Re: 580 CK backhoe motor? in reply to mEl, 02-12-2008 04:14:00
THANKS FOR THE INFO I THINK I HAVE FOUND A 201.
tom stanley
02-11-2008 20:35:03
Case was offering a kit to bolt a 4cyl Cummings in to the 580 series but was pricey check with your local dealer if you want a used motor find a 660 case combine they had a 201 gas or the 188 Dsl also Case 955-1150-1155 windrowers had a 159 gas lot of these have lower hours on them than the industrials had good luck
