430 clutch
Udell
02-10-2008 15:50:43
I have a 430 case thats on lp gas the clutch dont work or the power steering.when clutch is depressed it feels like nothing is there any body out there have any ideas .
Larry59
02-12-2008 03:23:35
 Re: 430 clutch in reply to Udell, 02-10-2008 15:50:43
I set and was just cussing about my tractor not moving now and it was working perfect. Hummmm put that lever in gear and off I went... talk about feeling a bit silly. "I DID!" lol
j.c.n.
02-11-2008 12:13:43
get a itt book and a gage. it will explane how to check the case-o-matic pressure.had one with the pump drive shaft broke off in bottom of trans housing. sounds like a case-o-matic,it has no clutch as you know.
aw hadden
02-11-2008 09:05:26
Is this a 430B ? You might have a case-o-matic.
Gene Dotson
02-10-2008 18:33:30
Do you have the hand clutch lever in the forward position? Maybe redundant, but something I have overlooked... Gene
Udell
02-11-2008 12:15:47
 Re: 430 clutch in reply to Gene Dotson, 02-10-2008 18:33:30
sorry fellows but on closer inspection of the I D tag this tractor is a 411 b sorry for the mix up and thanks for all your help
Udell
02-11-2008 05:50:40
dont have a hand clutch that I have found. it has a handle on the right side of the steering wheel that has something to do with the clutch as is goes to the piston beside the one that the clutch pedal operates.I have a manual ordered but hasnt arrived yet.
J Heitkemper
02-12-2008 08:57:33
 Re: 430 clutch in reply to Udell, 02-11-2008 05:50:40
OK You have a Case -o- matic , Probably Larry 59 has one also ,. Unles Someone is there with You that knows alittle about this tranny . Get a Book , It will help clear all Mysteries and misconceptions.According to All your reports All conditions Seem normal.. Once you understand and become Proficient with tranny , you will either LOVE OR hate this tranny ,, Personally I LUV the 800 Case-omatic ,, Feel free to contact for more info
WARNING DO NOT LEAVE TRACTOR WITHOUT LOCKING BRAKES ,, TRUE AUTOMATIC , IT CAN ROLL AWAY ,, Best wishes , Jim
j heitkemper
02-10-2008 19:56:15
May be redundant as Well, check the Range selector as well ,, my nephew goofed by shifting into neutral and walked a milehome , chuckle , Need history details so not to describe all possibillities ,
Udell
02-11-2008 06:07:22
 Re: 430 clutch in reply to j heitkemper, 02-10-2008 19:56:15
it is not the range selector as I have tired it in all positions.as for the history I dont know anything about the tractor as I just bought it over e bay it was low on fluid and filled it but didnt make any difference. I supect that the power steering is conected in some way because the hyd.hose to the steering comes from where the clutch pedal is conected on top of tor.tube
