starter bolt
jerrys
02-09-2008 19:23:12
i have a case v.a.c and my starter has a bad bolt that connects to the battery i was going to see if you can change the bolt?
jerrys
JSTPA
02-11-2008 05:49:15
 Re: starter bolt in reply to jerrys, 02-09-2008 19:23:12
If it's a 5/16 stud, take it to a starter rebuilder and get a stud extension for it. You cut the stud off at the nut, remove the nut, then screw the extension on the threads that were under the nut.Works very well and alot easier than replacing the whole stud. JSTPA
Bob DeVol
02-10-2008 09:38:12
If it's a matter of striped theads- head to some place that sells electrial products (Home Depot-ect). You can find a clamp that attaches to a ground rod, it has a stud and nut on the side. Tighten the clamp around your starter bolt then your battery cable to the remaining stud. Easy fix!
old
02-09-2008 20:57:49
If its like most starter it can't be changed unless you have a very big soldering iron and the know how to do so. When I say bit I mean even the biggest soldering gun you can buy will not do the job. Any good alternator/starter shop can do it for you and not cost all that much
