oil levels 730
steve 8756
02-07-2008 08:18:25
on 730 case Thear is 3 drain plugs not counting motor now I can see where you check and ad oil at rear end . can any one tell me whear to check and ad for the other 2 please or are all 3 conected I have draned rear end but thear is still oil at other 2 plugs
TexasWren
02-08-2008 06:52:53
 Re: oil levels 730 in reply to steve 8756, 02-07-2008 08:18:25
There's three drain plugs because of barriers inside the tranny that keep it from draining completely (actually, on my 830, there's a fourth plug, on the left side, for draining the top of the range case). Even though you can't drain them all with one plug, you can fill all the sections through the back, because as you fill it, the oil will overflow the dividers and fill each section.
Tom N OK
02-07-2008 10:08:20
Hi Steve Drain all three places and fill at back of tractor. It fills all three compartments.
Tom
DKase
02-07-2008 12:30:28
 Re: oil levels 730 in reply to Tom N OK, 02-07-2008 10:08:20
Tom is right if you have 2 shifters. If you have a pre 1962 model with 1 shifter the hydraulic oil is filled under the seat.
steve8756
02-07-2008 10:54:52
thank you tom i will do that .I did not want to drain them when coudnt see where to refill
