VAC hyd's differences????????????????
RIckyp
02-06-2008 19:32:00
I have a 51 Vac that has an eagle hitch on it. I brought one home tonite that has a hyd valve by the belt pulley and a cylinder on the opposite side that runs a three point system. Is this as strong as the eagle hitch system? Just wondering which tractor would be best to fix up. Thanks, Ricky
mj
02-08-2008 11:03:04
 Re: VAC hyd's differences???????????????? in reply to loneranger27, 02-06-2008 19:32:00
Casekernel said: (quoted from post at 09:59:52 02/08/08) Just wondering if those conversion type Eagle Hitches are available anyplace,i.e. for the high pressure hydraulic system.
Yeah, I looked for a source about 20 years ago but never found one. I went so far as to getting measurements from the parts sheets (comparing the known dimensions of some pieces that I did have with those on the sheet to get an approximate scale) in order to fabricate a new/old conversion kit. I gave it all up after I acquired a tractor with a factory conversion kit on it. The problem is the links that go from the 'wishbone' to the rockshaft. Getting on and off of the tractor became a major headache and stepping over the links was almost dangerous.
third party image
I decided to do this instead and it has worked out really well:
(More at: Link)
third party image
You can see the parts breakdown for the add-on Eagle Hitch at: Link
Keith-OR
02-07-2008 23:04:44
 Re: VAC hyd's differences???????????????? in reply to RIckyp, 02-06-2008 19:32:00
The VAC with eagle hitch would be the best, as it has live hydraulics. The hydraulics off of the belt pulley is high pressure 2000psi but a lot less gpm of flow. And it is not live hydraulics.HTH
Keith & Shawn(Special Olympic Champion)
C. Amick
02-07-2008 16:15:45
The belt pulley pump is not live, but I am told that it can produce more lifting power than the engine mounted pump.
mj
02-06-2008 19:52:46
 Re: VAC hyd's differences???????????????? in reply to Jeff Neher, 02-06-2008 19:32:00
Fix them both up and put a 3-point on the early one with the belt pulley pump.
third party image
There's more info on the link -
Link
Casekernel
02-08-2008 07:59:52
 Re: VAC hyd's differences???????????????? in reply to mj, 02-06-2008 19:52:46
