Case 211-B P.T.O.
Allan Lance
02-06-2008 16:55:52
Hey guys. I was just wondering if my CASE 211-B has live power take off and hydraulics. I would like to run a small snow blower with it and live power take off would be best. Also is the long lever that exits the bell housing just ahead of the clutch pedal some kind of shuttle shift? I notice there is already a reverse on the sift pattern so I wasn't sure. The tractor will only move when the lever is pushed fully ahead, otherwise it just acts like its out of gear. Anyhow I hope that that was clear what i was trying to say, thanks for all the help in advance
Allan
Joe (Wa)
02-06-2008 17:39:21
 Re: Case 211-B P.T.O. in reply to Allan Lance, 02-06-2008 16:55:52
" acts like its out of gear" that's cause it is out of gear when you pull the lever back. The lever operates the hand clutch discs in the torque tube to engage/disengage the transmission for ground travel.
The pto shaft is powered by the engine foot clutch, giving you a "constant running" PTO. Kinda semi-live. If the blower clogs up, disengage the hand clutch to stop ground movement until the PTO clears it.
The hydraulic pump is splined to the pressure plate, pump pressure is available anytime the engine is running unless the pump drive is disengaged at the lockout plunger.
Joe
