sc clutch she's a slipping
buford
02-05-2008 18:15:54
I need a clutch disc for a case sc ours is oil covered, does any one know what will interchange our parts store don't have a clue, just bought her and want to fix a few things tin is extra good, runs good just needs a little care thanks for your help
Walt Davies
02-06-2008 15:08:33
 Re: sc clutch she's a slipping in reply to buford, 02-05-2008 18:15:54
I suggest going on ebay.com and getting an original case SERVICE manual they are far better than the IT manuals and cost about the same.
Walt
C. Amick
02-05-2008 19:35:35
You will find an oil drain hole in the bottom of the bell housing. You need to drain this oil out every time you change the engine oil. If there is a lot of crud built up in the clutch compartment, you may want to clean it with some diesel fuel. It could be slipping because of the crud build up from where the previous owner didn't chnage the oil.
Ry
02-05-2008 19:29:19
Yea - the SC has a wet clutch they are made to run in oil shared with the engine crankcase. Might be able to get the clutch disk relined if it is worn. If it is not showing much wear maybe it just needs to be adjusted.
old
02-05-2008 18:53:56
Would you believe the clutch is suppose to run in oil, thats just how they are. All it needs most likely is to be adjusted. If you plan to keep it buy an I-T manual for it. Clutch parts for the SC can be hard to come by. I know I have been trying for a few weeks now. I ended up takeing my parts to a machine shop to see if they could weld it up for me. Also would help if you gave the year or serial number and also what type of clutch if has, hand or foot and if it has live PTO or non live. Parts for them all all different.
buford
02-06-2008 04:46:49
 Re: sc clutch she's a slipping in reply to old, 02-05-2008 18:53:56
Thanks, to all who reply, I will certainly get a IT manual I WLL put her back together and adj. it The disc does not show much wear it is a 1949 year hand clutch no live PTO really a nice little tractor to good to let go to salvage a little paint and little care she will be good to go to a show Thanks to all Buford
old
02-06-2008 08:52:49
 Re: sc clutch she's a slipping in reply to buford, 02-06-2008 04:46:49
WARNING, as per the I-T manual C-201 which is the one you need. When you put it back together you slip the pressure plate and the clutch disk on the transmission input shaft and then bolt the engine to the rear end, then through the clutch inspection plate you bolt the pressure plate to the flywheel. Because of it having the over center type of clutch you have to do it that way or you can/will run into problems when you try to put things back together
buford
02-07-2008 18:55:06
 Re: sc clutch she's a slipping in reply to old, 02-06-2008 08:52:49
Old, you have helped us more than I can say, we did as you said and cleaned her up and put her back and the clutch DOES NOT SLIP!! thank you and to all who responded this is a really good place on these old tractors Thanks , Buford
old
02-07-2008 20:39:43
 Re: sc clutch she's a slipping in reply to buford, 02-07-2008 18:55:06
Always happ to help if I can. Now you want to here the funny part. I just got an SC a couple weeks ago and it has clutch problems. I have it in my shop right now split in 2 working on the clutch. Up till then I knew nothing about the SC clutch but I learn fast and read when I'm not sure
