DC Belt Pulley
LarryNeohiocase
02-05-2008 13:22:35
Anyone care to share with the the trick for removing the belt pulley from my DC? I was thinking a pulley puller after the 4 center bolts and plate were removed...
Thanks a ton!!!!! !!!
Paul f
02-06-2008 08:34:05
 Re: DC Belt Pulley in reply to LarryNeohiocase, 02-05-2008 13:22:35
Sounds like you have the resilient belt pulley. If you have the plate off you will see four grooves on the pulley that line up with 4 grooves on the hub. the resulting hole has a 1/2inch diameter rubber rod in it. I should imagine the rubber rods are the sticking point...so yes a puller should work. Putting it back on with the rubber rods is a major PIA....I left mine off, it makes shifting easier as the extra weight of the pulley makes it harder for the clutch brake to stop things...
LarryNeohiocase
02-06-2008 08:36:52
 Re: DC Belt Pulley in reply to Paul f, 02-06-2008 08:34:05
Paul,
Thanks but I'm not 100% sure about the resilient pulley thing. The darn tire is in the way to get a really good look inside.
Larry
Paul f
02-07-2008 05:58:03
 Re: DC Belt Pulley in reply to LarryNeohiocase, 02-06-2008 08:36:52
Is your DC a later model??? I looked at the parts manual and if there was a flat round plate that came off after you removed 4- 3/8x7/8 inch bolts you have the resilient pulley with the rubber pins. I think the older non resilient pulleys did not have the round flat plate.
C. Amick
02-05-2008 19:30:39
If the tractor is running, I would remove all the bolts, add some penetrating oil, and take it for a spin to see if it will break loose.
LarryNeohiocase
02-06-2008 04:01:45
 Re: DC Belt Pulley in reply to C. Amick, 02-05-2008 19:30:39
No, it is mostly disassembled. So taking it for a spin is not an option. But THANKS!!!!
C. Amick
02-06-2008 18:12:54
 Re: DC Belt Pulley in reply to LarryNeohiocase, 02-06-2008 04:01:45
Can you wedge some wooden blocks behind it to try to force it off?
LarryNeohiocase
02-07-2008 03:14:03
 Re: DC Belt Pulley in reply to C. Amick, 02-06-2008 18:12:54
That might be a possibility. I'll have to give that a try. Thanks C
