injector pump troubleshooting
TEX MARTIN
02-05-2008 08:25:02
I HAVE A 930D CASE, THE INJECTOR PUMP CAME OFF MY OTHER 930D CASE WHEATLAND I RUINED A CRANK IN IT HAD SHUT OFF TRACTOR WITH FUEL SHUTOFF IN PUMP I KNOW PUMP WAS GOOD HOWEVER IT DID SET A WHILE FUEL EMPTY. PUT PUMP ON CURRANT 930 THAT HAD FUEL PROBLEMS FROM BAD FUEL. WE HAVE FUEL TO THE PUMP WE HAVE FUEL COMING THROUGH THE RETURN LINES BUT NOTHING THROUGH THE PUMP TO THE INJECTORS. ANY IDEAS? THANKS
TimMiller
02-05-2008 20:39:32
 Re: injector pump troubleshooting in reply to TEX MARTIN, 02-05-2008 08:25:02
check to make sure you have your kill cable lined up right. If that is off then you wont ever see any fuel out to the injectors. Also crank the throttle up some while cranking.
