SC Water Pump
Scott Batts
02-04-2008 17:25:47
OK guys, working on an SC water pump with a leaky shaft seal, do all of the components press out of the side with the bolted on cover or do I need to pull the pulley off first? Any help would be appreciated
thanks
Kevin Meier
02-04-2008 17:37:52
 Re: SC Water Pump in reply to Scott Batts, 02-04-2008 17:25:47
Take off the pulley first. It should be a tin pulley that sits over the top of a 4 bolt hub. Pull the hub off. There is a snap ring holding the bearing in on the hub side. Remove the snap ring and press the bearing out the hub end of the pump. The easiest way to build that pump is to bore the casting and put in a unitized seal if you have the right tools to do so.
