CC Water pump
mshultz
02-04-2008 11:27:51
Got a CC parts tractor - hoping to combine it with my C to have a nicer tractor. 2 questions at the moment:
1. I'm trying to remove the water pump - got it about 1/2" out, but stops there. I broke the one on my C at this point.... what's the trick??
2. Will the one from the CC fit the C? I got the one from the C welded up, but would like to have one in there that is whole.
3(forgot one). I assume the one from the CC will need seals, etc. - has been sitting for probably 30 years. Where can I find seals??
Thanks for the help!
doug boll
02-05-2008 12:09:24
 Re: CC Water pump in reply to mshultz, 02-04-2008 11:27:51
no seals, clean up two hard steel washers and coat with waterproof grease, assuming bearings and bushings are good.
DKase
02-04-2008 12:57:59
The only sure way to save the water pump is to pull the front sleeve, and work through there to get it out. Good Luck DK
Chances R
02-04-2008 11:45:19
I wish I could tell you haow to get them out without breaking but I cant. But I did make a tool to get them out if they are broken off in the block. Its a heavy duty slide hamer with a grab hook thing. It works very well if you do brake it off in the block. I can post piucs or may even loan it to you if needed.
