930- Advice on changing tire
RC farms
02-04-2008 10:01:39
I have a 1962 930 6 speed and one rear tire is very badly craked and split in places...so I want to replace this one...but i"ve never changed a rear tire. It has rear wheel weights. Are these Hard to get off and manage on to a trailer for hauling? any advice appreciated...
Thanks,
Ron
RC farms
02-05-2008 05:27:52
 Re: 930- Advice on changing tire in reply to RC farms, 02-04-2008 10:01:39
Thanks...very good advice from all of you...but I thinkI will have a tire service do it.
comfortking
02-05-2008 05:05:51
That 930 has hydraulics on it. get the remote cylinder and put the base of it on your draw bar, make sure you put a good bolt in for a stop. Next retract the cylinder and slide it toward the tire you want to remove. Use a piece of flat metal and place it between the ram and the bead on the tire. expand cylinder slowly and repositon several times to keep from tearing tire. This has workeed for me.
Klyde
02-04-2008 21:05:54
Awww come on guys, let him learn on a junk one. First,DON"T TAKE IT OFF THE TRACTOR!!! The tractor will hold that rim for you while you change the tire. 2nd is it loaded? If it is how are you going to unload and reload it. I took an old jet pump and mounted it under a old spray tank added a couple valves and faucets and it works slick, loading and unloading. 3rd if the tire is shot just cut it off, easyist thing in the world. Sawzall the tire and use an angle grinder on the beads. When you get the new one on don"t spare the soap! You can never put on too much. Have fun. I been changing them for 40+ years and they always got done and I never took one anywhere or called anyone to do it.
Jim McVay
02-04-2008 19:00:53
My dad and I do all of our own tire work. The hardest thing to do is break the bead loose. If you lay it flat and soap up the beads and pound on it just right with a duck bill tire hammer your just getting started. If we do it on the machine I use my works $1000 hydralic bead breaker. The rest is just like a bicycle tire.
Jim McVay
02-04-2008 19:00:17
bradley martin
02-04-2008 13:26:07
Not only would you need to buy some tools. do a lot of work, etc. if it your first attempt, the odds are that you would buggar the tire, tube and/or rim. Guys that do it all the time make it look easy, but if you don't know what you are doing it is darn hard. Call a tire service.
LarryNeohiocase
02-04-2008 12:23:03
Let the guys that do it for a living take care of it. I have switched complete tire and wheels around and that's not too bad, (thanks to the 30 ton chain hoist LOL). But breaking one down and remounting!!!!! !! Not in my garage I'm not.
tomturkey
02-04-2008 11:21:54
call the local tire shop with a service truck. They can have the project done before you can round up the tool and get the wheel weights and tire assembly off the tractor. Getting that tire/rim off and laid down without a cherry picker is a bit dangerous , very dangerous. I about had one lay down on top of me once. Please be careful what ever you do. gobble
Glenn F.
02-04-2008 10:21:45
You will not be removing the wheel/rim. The job is done with it fully mounted on the tractor. Breaking the bead of a tire that's been mounted for 20+ years can be very difficult if you only have BASIC tire tools.
Glenn
RC farms
02-04-2008 10:40:41
 Re: 930- Advice on changing tire in reply to Glenn F., 02-04-2008 10:21:45
Thanks, I guess this would be expensive to have a co-op do it? Just thinking about buying the tools and how often I would need to use them to change tires.
Walt Davies
02-04-2008 11:48:46
 Re: 930- Advice on changing tire in reply to RC farms, 02-04-2008 10:40:41
Usually about $75 to change one at home you can buy the tools but who is going to do the work.
Walt
