can you detail that a little bit more?
Larry59
02-03-2008 19:30:44
So it's a control lever. What exactly does it do to the draft control? Thanks
Tom (Ks)
02-03-2008 20:02:46
 Re: can you detail that a little bit more? in reply to Larry59, 02-03-2008 19:30:44
With the draft control shut off, the lift arms will stay where you have them set at whatever the load is. When the draft control is turned on, the lift arms will raise up a little if you hit a tuff spot in the field and then return to where they were set at. This will allow you to get through without downshifting gears. You have several settings on the lever to allow how much hitch movement or constant depth you want if you are plowing.
GEOMO
02-04-2008 05:24:01
 Re: can you detail that a little bit more? in reply to Tom (Ks), 02-03-2008 20:02:46
WHICH WAY IS OFF?
THANK YOU
