Case DC engine clutch oil
Dalton Sogla
02-03-2008 17:28:40
Is the engine and clutch oil all the same and tied together? Do you fill the clutch with oil at the same time you fill the engine with oil? This would be by dumping oil into the fill opening by the distributer. If it isnt all tied together, than how do you fill the clutch with oil? I drained the engine oil, and then pulled the plug out that my manual said was for the cluch, and I bet no more than an 1/8 of a quart of oil came out. This is why I am wondering. Thanks
ihc49er#2
02-03-2008 17:53:07
 Re: Case DC engine clutch oil in reply to Dalton Sogla, 02-03-2008 17:28:40
drain oil pan and clutch housing, then you only have to fill crankcase. the oil makes its way to the clutch from crankcase.those old cases are all the same.
