Case 300 300b dipstick
Joe (Wa)
02-02-2008 19:53:12
third party image
This the hydraulic dipstick Case p/n G14099 that I fatfingered and maded the thickheaded errors on in Jim's post. Same part on some of the higher nr series tractors also.
Larry59
02-03-2008 19:33:08
 Re: Case 300 300b dipstick in reply to Joe (Wa), 02-02-2008 19:53:12
Looks like you did a fine job making that. Looked good. So have you use it. Does it stay in the hole are have to be used each time for measurments of oil and pulled out?
Joe (Wa)
02-03-2008 20:30:05
 Re: Case 300 300b dipstick in reply to Larry59, 02-03-2008 19:33:08
Larry, I didn't make it, it is the factory dipstick for 300 300B and some later number series tractors
Look on the torque tube cover, just forward of the transmission shifter cover. On top, right front corner, 3/8" pipe plug, your 311b should have one to check hyd oil level.
Joe
