magneto
patsdeere
02-02-2008 13:29:34
I have a FM mag on my SC and was wondering about it after I started to take it apart.
In the area where the lug contraption thing sits, there was 1 round shaft screwed into the casing so that when the lug thing would spin it would hit it. Directly across from it there is another spot for one of these smooth round screw things, but there isn't one there. My question is: what are they and is there supposed to be 2 or just 1.
Thanks
Nebraska Kirk
02-02-2008 14:39:52
 Re: magneto in reply to patsdeere, 02-02-2008 13:29:34
The is only one. The other hole is used in applications where the mag turns in the opposite dirrection.
patsdeere
02-02-2008 14:43:29
 Re: magneto in reply to Nebraska Kirk, 02-02-2008 14:39:52
Thanks a bunch.
What is the easiest way to test these things when they are off the tractor?
Nebraska Kirk
02-02-2008 15:38:19
 Re: magneto in reply to patsdeere, 02-02-2008 14:43:29
I just stick a plug wire into one of the sockets, hold the other end about 1/8 to 1/4 inch away from the mag body and with a pliers or by hand, turn the impluse coupler untill it snaps. You may have to do this several times before the rotor will turn to the socket where the wire is. You should see a blue spark jump from the wire to the mag. If the spark is yellow and you have to hold the wire really close to the mag before the spark will jump the gap, then your spark is weak, meaning likely a bad coil.
patsdeere
02-02-2008 15:49:51
 Re: magneto in reply to Nebraska Kirk, 02-02-2008 15:38:19
Thanks.
