Tractor value
jh
01-31-2008 13:57:46
whats 300 diesel worth sheet meatal is ok fair it has eagle hitch an drawbar an high an low trans tricyle front
C. Amick
02-01-2008 09:18:26
 Re: Tractor value in reply to jh, 01-31-2008 13:57:46
If it's the old Continental Diesel engine, I wouldn't give much for it. You can't get parts for the engine and the pistons are bad about cracking. $1,000 might be a good price.
600
01-31-2008 19:39:39
will some one tell me the deck hight for a600 with a377 engine
old
01-31-2008 14:37:22
Need a lot more info to help with that. From what you have said it could be scrap price to around $3000. Tires, does it run, does it smoke badly or leak oil all over the place etc. etc.
jh
01-31-2008 14:57:29
 Re: Tractor value in reply to old, 01-31-2008 14:37:22
Well i just looked @ it the man said it ran but i didnt crank it up the sheet metal is rough hour meter is showing 8248 an the front grill is missing the motor had lots of oil on it all the tires an rims looked good the hitch was all there its probably gonna have to have a motor rebuild from a 1 to 10 scale i would rate it a 3 or 4
old
01-31-2008 17:38:07
 Re: Tractor value in reply to jh, 01-31-2008 14:57:29
I would say a $1000 tops if that much but of course with out seeing it I can only give you and idea
