case 411B
dennis repaal
01-31-2008 12:15:59
guys- what can you tell me about a 411B case. are they gas or deisel and how many horse. the good and bad about them.thank-you dennis
Texas Sand
01-31-2008 21:24:22
 Re: case 411B in reply to dennis repaal, 01-31-2008 12:15:59
I have a 411-B I enjoying working around the house and shop with. Until you understand the Case-O-Matic you may not like it, when you get the hang of it you will like it. Plenty of gears to choose from. They will grind shifting, esp. if the oil is the wrong type or cold and thick, and can be jerky clutching it. The hydraulics are pretty impressive for a little old tractor. It will pick up a good bit of weight and the SCV seems to flow well. For it's size it pulls very well and will run 25+ mph in road gear!
Joe (Wa)
01-31-2008 17:07:41
411B is gas 148 cid engine with Case-O-Matic, COM is very good when it works, very bad when it doesn't (spendy). HP ~29 ~33. Other than COM it is pretty much the same tractor as the 311B, many parts are interchangeable. All I know about them.
Joe
